they are what I CALL roll welded,put in a machine and welded with electric current.you have to cut the metal outer wheel well off,leave the flat of the outer well on there,take a grinder carefully grind the flat flange away. hint when the metal gets thin and turns blue STOP, use a pair of plier's and wiggle the thin metal loose,use a 3 or 4 inch pad grinder to finish,go slow not to make the inner flange thin.
Thanks!
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
