Re: 34 plymouth question
[Re: dogdays]
#114799
09/05/08 06:37 PM
09/05/08 06:37 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
The Mustang II generic aftermarket front end is the natural one for your car. They are available from about a million vendors, just buy one copy of Street Rodder. I personally like the tubular A-arms that look so much better than the stock MII stuff. You can spend as much or as little as you want for this stuff, even available in polished stainless steel. It is the right size, the MII front end was way overbuilt for the car and it has been used for everything from Model As to pickup trucks. You can put any kind of brakes on it, the possibilities are endless. The suspension geometry is also good. They drive and steer right. There are other choices but they aren't as good, except maybe the Jaguar derived kits which are in another league price-wise as well. There is a reason that just about every street rod built since 1980 has the MII derived IFS and that's because it is the right tool for the job.
I love the 33-34 Mopars, they have better lines than about anything you will find.
R.
I would say that "IS" the way to go Ron....
