For what model? 2-sp or 3? 70/2E and 71/2B til 9-71 had veriable speed then 3-sp after that. Bet RA 72 is not correct either. Stating in 73 all -3speeds had a plastic cover
the diff between 3 speeds and variable is actually at the switch not really at the motor
Dunno what you mean about "plastic" cover
the diff between earliers and lates at least on 3/var speeds is lates have a "tower" on cap ( maybe this is what you meant about the plastic cover ? ) for the parking and turn off switch, and earliers are flat
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
