I used a tilt column from an early 80's Dodge pickup since the turn signal housing at the base of the steering wheel were small diameter. Many of these had cruise controls and were much larger or square-shaped which I did not want. Since I am using a Viper 6-speed manual, I cut-off the automatic column-shift stuff I didn't want or need and ended up with a simple-looking column that happens to have tilt. Other than the turn signal arm, the small tilt release arm is all that is visible. This is also a Saginaw unit that was widely used so parts are readily available.
- EM
