what was your compression height, cab? i know how you love those short short pistons. i've run .032 piston to head with taller pistons, 6500 rpm maximum, steel h beams, fairly loose clearances (.007 piston to cylinder). i've never gone less than that. compression height on that one was about ~1.5? no evidence of touchy the heads.
for what is the good life if not doing things thoughtfully?
