Quote: I found this pic but I'll measure the center with pics tomorrow of mine
My brother put them on his 91 ?
I'll ask him, but, those are the stock rims I like
Those are the rims I was talking about in my earlier post. YOU WILL have to enlarge the center from 3" to 3.5" if you get them off a 1500, unless, like mentioned earlier by another member (76dodgeboy I think), you get a set off a B250 van, those apparently have the larger hub hole. Any compotent machine shop can bore those out, either by lathe (probable method) or by mill with a rotary table
