Hands down Stage 5 the castings are nice.
X2, but in the Millenium style with the exhaust valve rotated 2* so you can run the bigger intake valves. Also, I would go with the 10 bolt style for the larger intake ports. The sixteen bolt ones crowd the intake ports too much.
If considering Indy, then I would go with RA6 heads on a motor like that. They already have those features and they flow in the ball park of the Millenium heads.
The biggest advantage I see with the Stage V heads is the use of the T&D individual rockers like the SS guys run.
