From their catalog: "These are original designs with slower ramps and std. valve lash .026-.030"
R11 316/283/202 .4544" The 'R' designates roller. The '8' designates 108 lsa. You can compare the profile to a similair CompCams grind and use their explaination of it's relative dynamics. But, IMO that is an aggressive profile.
I dont see the cam listed, I see similar ones. I know the 311 is adv duration, and R8 is listed as a master number?? Those numbers arent correct... The second number is Dur@50 which I know is 278° not 283°.. I will call them...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
