no they are not fenderwell headers, but you will have to open a passage in the fenderwell for one tube.
The link says...One pipe one side over frame.
Actually it's 1 pipe on each side ( 7&8 tubes) go through the fenderwell and over the frame.
I have that exact set on my Valiant. Oh, and forget running a "kickout sump" pan with them. Either have to run a moroso style straight sided pan, or have a your pan cut and modified.
