You need to goto jeepstrokers.com, you are probably looking at a wiped cam lobe. When they removed the zddp from the oil, many people were only getting about 30K miles before the cams went to [Edited by Moparts - Family Friendly Site - Keep it clean]. When you have the pan off, check the cam from the bottom. Been there and done that. Tim
