my buddy and i spent the day taking out a 408 and trying to put back a 360 back into his 69dodge dart that come with a 318. we cannot get the drivers side motor mount to line up, we are a little less than a 1/2" off.
he is putting a solid mount on drivers side and rubber on passenger side. the passenger side is matching up perfect. we cannot get the drivers side to match up. the only way to get to work is to use a die grinder and wollow out the hole to give some room, then the mount is at an angle and looks as though it will not hold up.
he is trying to put a 1973 360 into a 69'dart and we cannot get the drivers side mount to work. has any of you A'body guys come up with this when swapping a360 in a 318 car?
