With the big cam the higher 10.8x compression ratio with zero deck should work fine. I'm running 10.2 and zero deck with a smaller 242@.050 cam and no problem with detonation at all.
With standard port heads and 493 ci it will be done by 6000 RPM regardless which cam you use.
