Check out the thread going now in the resto forum on go to guys for dash work. Several very good contacts listed. There is a guy I used named Scott. Copied from the thread below......
ESE & Associates, Inc
Scott
630-372-7648
This guy is by far the best guy I have found. He only does what is needed. If the faces are good he just cleans them. Same for his gauge resto. He will give you an estimate before any work is done. I have used a couple of the ones listed and was blown away by the difference in pricing
