flexplate is the same, if you are switching from 904 behind a 360 then the converter will be weighted for external balance and you will need to get appropriate weighted converter for 727. Driveshaft is approx 7" shorter on 727. Dipstick is different. Linkages are probably different unless using aftermarket shifter.
