Please confirm the path of flow for the engine coolant leaving the cylinder heads on this engine?
I noticed coolant ports at the rear of the heads, but these are blocked off when the intake manifold is installed.
Does all coolant leave the heads at the front coolant ports, then thru intake, thru t-stat, and back to radiator top?
