Since there is no way tp turn off the traction controll on a 2010 Challenger RT I was real bummed out that burning rubber was not an option. This car is a 5.7 6 speed manual. I have now figured it out.... By simply removing the fuse. This car will light up the tires like nothing, it is great!!! The only problem is that the speedo does not work, the gas guage does not work and the electric gate that keeps you from shifting into reverse at high speed is not activated. When you shift into 5th gear be careful...
