Weight transfer. The motor remains in the same location, so the percentage of weight on the rear wheels will increase if the wheelbase is extended. AFX cars moved both front and rear wheels forward to put more weight on the rear tires. Also, some people used to stagger one front wheel (move one forward) to increase rollout if the driver had problems red lighting (junior dragsters have this built into the chassis because the tires are so short).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
