Never undid PB's so forgot about the large firewall opening so if it has that I believe you'll need the OE plate (or fab a similar one) to cover that then the aforementioned 4 to 2 adapter. If Summitt confirms that that M/C has the shallow groove for the manual brake pushrod neoprene retainer to lock into it'll work for you. If the firewall opening is covered and the M/C mounted with the right adapter you're (pretty much) good to go
