OK Gents.... Today I talked with my mechanic and he said that the first ring is .017" & second is .022". I started and warm up the engine, then I pull out all spark plugs and turn manually and the engine is very..very hard to turn. Maybe on this week end we pull out the engine and check everything again. I'm thinking go to more clearance on Piston to wall, what about .010"??
