Cab I did notice that when I pulled the vac cap off of the dr base nipple to attach a vacuum gauge the idle sped up a bit & got slightly choppy (stock 318). I definitely need to buy an LM1 wide band so I can get the eddy 1406 spot on. I'm guessing right now
