Quote: Uhhh.... An external feed Bb pump allows you a straight shot feed to the pump and eliminates the 90 degree dog leg, that's one of the benefits of running one
Most of the Milidon external dual line systems I have seen have 90 degree elbows coming out of the swinging picksup I like to use straight AN bulkhead fittings in the pan and 90 degree female elbow fittings on the hoses
