The guys have several good thoughts of why this might happen. One thing I have seen repeatedly that can cause this is incorrect pushrod to rocker geometry (basically wrong pushrod length). This bad angle between the pushrod and the adjuster screw puts pressure on the screw which in turn puts pressure on the aluminum threads eventually wearing them enough that the screw will not stay tight.
Kevin
