The calculator said a 9.27 in a perfect run with your mph. I was figuring 9.50's on your first outing figuring you probably will not make that perfect run first time out. Did you make another pass? How fast did you go? Sounds awesome.
Getting old just means you were smarter than some and luckier than others.
