Re: Can I get a little help reading some plugs please.
[Re: Cab_Burge]
#1098405
10/22/11 12:59 PM
10/22/11 12:59 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Once the plug is colored up it is harder to read, try a new set and hit it once at WOT and pull the plugs, look for a very narrow pencil like mark on the ground strap(no color yet on one hit ), You want it in the middle of the bend, if it is not in the middle,IE one third from the body or 1/3 third from the tip, then try a different heat range do you have a magnifier you can use? I use a 10X dental plug reader It is amazing what you can see with magnification
X2
Hi Troy, how have you been?
NGK's are preferred because you can see the cadmium burn line on the ground strap. Fuel ring on the porcelain should be mid way up and watch for aluminum on the porcelain as well (detonation)
And one other thing, dont use anti-sieze with a power adder, it will make the motor detonate.
8.30's @3400 lbs
