Hello,
Car has stock suspension setup and locations. Running 15x7" wheels in front and 15x8.5" in the rear. I don't have the BS. I will check when I get home.
I currently have P255/60R15's on the back and P235/60R15's on the front. The fronts are dry rotted and need to be replaced. Already replaced rears with Cooper Cobras....so fronts will be Cooper Cobras as well.
Question is should I go back with the 235's or go with P215/70R15's.
I have not been to any car shows lately to look at tire sizes. Cooper does not make a 225 in the radial g/t's.
The wheel/tire height is basically the same front and back if I go with the 215's.
Does anyone have some pictures and/or opinion on my dilemma.
Thanks,
Mark
