1. Go buy another JY 360 short block (or fix what you got on the cheap) and put the car back together ASAP. 2. Do the post-mortum on the current short block, and determine if it will handle a stroker heart. 3. Gather parts to do a real solid short block over time and build it right. 4. Swap it out and fix any other little bugs before next season starts.
Its probably a safe bet a Junk yard engine isn't gonna live long with your set up, too much power and a stick. Not exactly what those engines were meant for.
Get the thing back together and start collecting parts for a stroker ASAP
-Dustin 67 Dart, 9 second, 392" G3 Hemi 68 Barracuda 340 F/SA
