I got home this am and decided to mess with the old pump.
I had to take out all 8 allen bolts and it pulled apart.
The ones that go thru the motor also hold the motor/housing together.
I spun the motor with the allen wrench and it spins easier then my other one so I am not sure it's seizing up. I will swap motors and see what happens.
Thanks for the info and I figured I would update this incase someone else has to do theirs.
Have A Good Day Guys,
David
