I am going to go through the front end this winter. Maybe get some tubular uppers to get more caster in it!
We just rebulit the frontend on my Dart. Boxed in the lower arms and tightened the t-bar mounts and installed nylon bushings, We installed Reilly Motorsports Tubelar upper arms and their solid strut rods and Firmfeel lower control arm greasable pins. We upgraded the tie rods to 11/16 and installed PST adjusting sleeves.The caster is at 6 degrees now.The camber only moves 1/2 degree throughout the whole suspension travel and the toe only moves 1/4 inch throughout the whole suspension travel. Car drives awesome now!
