Called CamCraft. Nope. They don't claim it. They usually don't mark their cams. The owner said that it's likely a custom grind/regrind and said that I need to look at the casting for marks but even that won't likely tell the story. Might be an older Crane Cam number set, referring to the 1424. Suggested I go to someone with a "Cam Doctor" to have it measured.
I'm going to call my engine guy and see what he's got. Maybe do the calipers and dial indicator for fun.
Thanks for the suggestions, guys.
Lindy
In all honesty though do you really plan on re using it? If its a solid flat tappet, or hydraulic cam is it worth saving especially if you dont know what specs is ground on. I guess for what Comp will sell you a nice cam and lifter set for I would just buy a new one, but if your on a tight budget I understand that also.
kasey
