Glad you had some fun... its strange that it was running
150-160 with a 180 stat... stat should have closed
and keep the engine at 180... unless your stat starts
to open at 160 and is fully open at 180
Yeah, I thought it was odd, but happy it cooled. I really just expected it to be a head ache on the drive. Haha
That's a good runnin car you got there. Can you give us some details on the motor?
Thanks!
468ci small block.
1050 dominator
1/2" wooden isolator
1-1/2" moroso 4500 to 4150 adaptor
Victor W2 intake
Econo W2 heads
1.7 T&D rockers
2.02 intake 1.60 exhaust
52cc chambers
Comp cams 48 degree custom solid roller.
277/284 @ .050"
.748"/.714"
108 LSA
R3 48 degree 9.600" deck block.
4.185" bore
Ross reverse dome (16cc dish)
13.3:1 compression
4.25" stroke
6.3" rod
1-7/8" Hedman Huslers
3" crush bent exhaust, no cross over pipe, dyno max ultra flows with dumps.
727 torqueflite
8" Island converter. Stalls around 4000 on the foot brake.
Stock guts
Transgo full manual stage 3
Stock 8-3/4 rear with 3.23 gears and a cone style sure grip.
8.5 X 26 ET drags.
The car in street trim is about 3400lbs.
-Kenny
