Re: Engine builders, need some advice on my combo.
[Re: A34]
#1081473
09/24/11 02:43 PM
09/24/11 02:43 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I think you will end up with TO MUCH compression with this combination for pump gas Do the math and see what ratio you will end up with If it is above 10.0 to 1 do something else on the pistons, I'm assuming the pistons your planning on using are flat tops, if not say so and state what CC the piston tops are
Yes, they are flat top stock replacement pistons. I'll double check and if it winds up with too much compression, then I guess I can go with a thicker head gasket.
