any catlist system really should not ever go bad as long as its in reasonable temps.
I had 5 gallons of dark green epoxy primer from my uncle which he used litterly in 1968 on his air base. and 2 years ago after some serious shaking up it worked like a charm and probably bullett proof.
I dont want to tell you the chems that were in its make up or the car s would be a superfund site.
depleated uranium oxide is one
and mercury peclorate/benzene was the fixer.
no we dont need no stinking respirators----LOL
but to be honest the stuff was also to aid in anti radar reflection-the particles would randomize the reflected enemry radat, really no diff then the new composite stealth if you know the technology
We need a pair of crack-pipe toasting smilies !
