Quote: The addco, helwig, and hotckis rear sway bars will work. The helwig and hotckis dogbone connector links may need attention.
I know Hotchkis has a special bolt for clearence on the rear sway bar connector for moved springs. But I don't remember what the exact moved over amount was.
Steve – The special sway bar bolts we sell allow for additional bolt clearance when moving the rear leaf springs inboard 1 to 1.5” for wider tires. PN: 17366
