Well my 6 yr old Paddock gas tank sprung a leak last night (wonder if that's an indication as to why they're out of business?). Looks like the seam gave out on one corner so I have a couple questions.
Is this repairable and/or is it worth the expense? If not, where should I look for a quality tank?
Also, I've been looking for a reason to replace my obnoxious Holly fuelpump with a Mallory 110 so now's a good time. My Holly is currently up above the rearend housing mounted horizontally: will the Mallory be OK with that mounting even though they suggest a vertical placement?
Thanks!
