Geeez,
here we go with the "Cheap" chinese thing again!!
First question is,
Did you put the oil restrictor in your feed line??? I purchased the fitting with the restictor cast in it. Your turbo is probably getting too much oil pressure and pushing oil past the seals. As stated above, the oil return must have a straight shot to the oil pan....
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
