how will too much pinion angle affect my car? with trying to get my car as low as possible we found the pinion angle was pointing upward. i had my chassis man extend the holes so i can relocate the front ladder bar down further. unfortunatley the hole i want to use snaggs the rose joint on part of the chassis. so being the lazy buggar i am, i used the next hole down but found my pinion angle is about 6*. how is my car likely to react at this angle? it was already lifting the front wheels in the original position but the car would run straight and handle well at speed 140mph.
