you can slide it out---but get it as empty as you can and the car has to be far enough in the air for the tank to slide toward and under the differential-----pretty sure your gas filler sticks straight out the back like my 64----just did mine last week but i put a new tank in--- there will be one screw into the neck from inside the trunk too-bob
