Hi,
Any suggestions on gate plate option? I run reverse pattern and use the car on street and strip.
Anyone have experience of mounting rear exit shifters (winters standard shifter)? When looking at the instuctions, its seems like quite much brackets and also the shift cable routing back of the trans... Does installtion parts on trans clear a 3" system with H-pipe? Will cable melt of the exhaust system instead of the headers??
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
