There isn't really an answer for that other than the standard "it depends".
The six pack setup is a great design that works well in certain applications. But once you get outside of its design capability then it doesn't work so great. Same thing with the 850 DP.
I agree both work good within their limitations. From what I have seen the 6pk works as good as an 850 DP in any street/strip application. From what I have read in Andy's very good book I feel the 6pk might make more power then the old crossram setup does. Ron
