Re: Who is boosting 3rd gen Hemi's?
[Re: hemidup]
#1070901
09/19/11 10:06 PM
09/19/11 10:06 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
If someone had a target of 800hp /turbocharged with a 6.1 as the base what would be the areas that need attention first? I'm thinking pistons,rods,but beyond that not sure the next items to add to the list. Any advice would be helpful.
Piston rings, fuel, spark and crankcase evacuation under boost.
Fuel system is good,Spark,I own a Fast EFI system ,so I'm thinking the XIM should handle the ignition side with the factory coils? I doubt it will take over 15lbs to get where I want to go. Do you have any rod/piston favorites for this application? I'll give you a call soon.Thanks
