There is a rubber coated clamp under one of the trans to block bolts, looking at the engine from the rear I think it's the top right side bolt (maybe top left one though)
there should also be another clip on the tail shaft ext to trans case bolt.
I can snap a picture later today of where it connects on the firewall - I have a 69 Charger in the shop
