No, I didn't turn the engine over while the dist. was out. And the gear didn't come out. (Big blocks have slot, small blocks have gear?)
I like the idea of just moving the wires, I think I'll do that.
only suggested it cause the last time i pulled my dizzy it pulled the drive shaft up enough for the gear to jump a couple of teeth which totally threw off my timing (or wire position, which ever way you want to look at it)
happens all the time and that is what my bet would be!
