It went a little higher than normal, just not straight. Landed harder because of getting off the throttle. A couple good ideas given here. In order for me to take up the front any more I will have to raise the rear(not a big deal). I will lower the front and check the stops if I can do anything there. I am geting my converter adjusted and assuming that flashes where I want, I can then set the ladder bars for less air on launch. I see a lot of pics of wheels up launches and was curious if they ran into this. I will check my shocks as well.
What do you have for front shocks... they sounds like
they are wasted if it can fall that easy... but I
would raise the front some
