I had a similar problem on a small block that started and continually got worse. It turned out to be the ballast resistor for the coil. Check your primary voltage at the coil with key on and idling. You should have 6-8 volts.
Mine was only getting 2 or so and I was loosing spark.....
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
