Hi Folks:
I have a 63 dodge 330 that is currently a hemi that is throttled to low
tens@133.This winter I am going to put a wedge back in it.
The goal is a car that will do lap after lap without having to think about it, and do it on pump gas.
I have most of the parts for the short block.
440 block 2 Bolt mains .030 over
6.86 h-beam eagles
4.15 Mopar crank
milodon oiling
The car
Dana with 4.56 and mark williams spool and axles.
727 with a griner valve body
4500 Dynamic stall converter
also has a large aluminum radiator
The above are not going to change.
So, I need help choosing the rest.
Remember -- Lap after Lap after Lap and pump gas is the goal.
I'm not familiar with the different heads that are currently available
for the wedge -- I would prefer aluminum.
compression ratio? for aluminum heads and pump gas?
Cam? I have a good set of comp cams rollers leftover from a previous hemi build but I might even try hydraulic.
intake ?
Carb?
Tom
