Go junkyarding and find disks off another Abody. this is the cheap way. It will also change the front to the right blot pattern.
The Cheap headers hang to low. There are some brands that do not.
call 1 800 radiator for a radiator.
If you want the car to handle properly and not have mushy front end you need to change the bars.
While at the junkyard get the rearend from a v8 car and this will solve the problem of weak 6 cyl rear and fix lugs.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
