Quote: put 2.02 s on as is. 2.08 wont work with low lift cam,
This is why I explained the valve size thing, not directed at you p-body . Even NA the differance from 2.02 to 2.08 is very small but I do get tired of hearing that a bigger valve flows less at low lift crap
