The XS indicates the Charger R/T. The only engine options for the XS model in 68 would be the Hemi, engine code 73, or the 440, engine code 83.
If the engine code was 41, indicating a 318 engine, then the first two letters would be XP.
If this was an original XP car, indicating the standard Charger, then it was not an original Hemi car.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
