hello?where are all the hemi guys?
The is the HOT-STREET Hemi I built for the book that will be released in June (How to Build a Max-Performance Hemi". This picture shows EFI but carbs work just as as well.
It's also shows coil-on-plug but a distributor would work just fine too.
This is a 572" Hemi:
800 RPM idle at 14" vacuum
700 ft lbs at 3500 RPM (curve was very flat)
725 HP at 6200.
On 91 octane but it should be fine with 87 or 89, just haven't tried that yet.
World block, unported Stage-V heads.
With a hydraulic roller would be virtually maintenance free.
