You could also buy the bearings and measure the actual clearences. Your crank may be undersized out of spec but if your main bores are small as well you may end up with a useable clearance. Or grind the crank to .010 under as previously mentioned and just buy the right bearings from there, although it does appear you are doing this on a mega-budget so that may be money you dont have to spend.
